Serenity
Date:  12-20-2008
Brief Description:  Finish AFP fuel pump kit
OK, finally finished bending, cutting, and flaring the tubing. Everything was connected to the valve assembly and then placed into the fuselage for a fit check. So far, so good. Now, on to the temporary fitting of the tail section to the fuselage - I will move the fuselage off the rotisserie and onto the workbench, then put on the horizontal stabilizer and secure it, then the vertical stab/rudder. I also will be installing the control pushrod that goes from the control stick all the way back to the elevator horns (actually two push tubes that share a bellcrank behind the baggage compartment).
Spaghetti o' tubes
Spaghetti o' tubes
Fuel pump, filter, manifold, bypass valve, and the fuel valve (red)
