Brief Description: Center fuse assembly - riveted bottom skin
Chad Jensen ( http://www.chadandbrittne.com/RV-7.htm ) came over to help rivet - thanks, bud. We knocked off riveting the bottom skin in 1.5 hours. Rest of time spent clecoing seat and baggage area skins, then riveting the outer 915 seat rib. Pic 3 show the rib fwd flange wrong - it should have been clecoed inside the spar flange. This got discovereed and corrected next day.
Chad on the gun, me lying underneath with the bucking bar
Floor skins in place - makes everything damn stiff and solid.
Outer 915 rib - for any of you builders - note the fwd flange should be INSIDE the spar flange,not out
