Brief Description: Center fuse - corner ribs and cut back seatbelt an
Fitted and drilled the baggage area corner ribs. There are small plates that connect these for and aft. I goofed one rib by cutting too much off the aft end - made a longer plate (in pic 3). Also needed to trim a couple of the seatbelt anchors so the seat ribs could fit (pic 1 and 2).
