Serenity
Date:  11-25-2007
Number of Hours:  3.00
Brief Description:  Finish F-706 bulkhead
Assembled fabricated L-angles to the F-728 and -729 ribs, then clecoed those and the F-706 bulkhead parts including the F-730 reinforcement plate, then riveted everything. I did drill a botched hole where the manual trim cable is to go if not using electric - I was going to use it for a wire run, but later elected to move over lateral. I will need to pierce the baggage floor rib later on, but fine with me.
F-728 channel/rib
F-728 channel/rib
Everything riveted
Everything riveted
Closeup of elevator bellcrank position - will connect to pushrod to elevator and one forward to stick.
