Riveted F-705 bulkhead parts together, being mindful of holes that need to be left. Also bolted the seatbelt anchors (pic 1). Next, started on the F-706 bulkhead by assembling, drilling holes for rudder cables and one in the bottom section for a wire run (was supposed to be for a manual elevator trim cable, but I'm using electric). I also got the parts out for the remaining bulkheads out to the tail end.
Seatbelt anchors in white
Finished F-705 bulkhead
F-706 - this shows fuse shape, whereas F-705 is more foreward and has the canopy over it.
