Brief Description: Final riveting upper wing skins
Marathon session on the left wing upper skins - after playing with different techniques, I decided to use the flush swivel set/tungsten bar technique. I felt the rivets were slightly set better than with the backriveting technique. Problem isthe marring of the aluminum by the set, but a little cleanup with the scotchbrite maroon pad cleaned everything up nice.
Austin on rivet gun
Learning to buck
Almost done - lower spar rivets to be done with squeezer
