Brief Description: left wing leading edge construction
Construction of leading edge - attached nutplates to splice plate, clecoed skin to ribs, riveted with squeezer aft 3 rivets, then rivet gun and new tungsten bar used to buck rest. This bar is awesome due to its small size yet higher than steel mass, and I probably will not need to use any other bucking bar here on out except in rare cases.
4 inch yoke/squeezer in action on aft 3 rivets
Tungsten bucking bar - worked very well in tight spots
Finished rivets and W-919 splice plate with nutplates attached where tank will fasten
