Brief Description: HS skin to rear spar assembly and finish
Finished the HS! Clecoed the rear spar across both joined halves, and cruised with the pn. squeezer on the skin to spar flush rivets. The blind riveter was brought out again for the spar to rib connections except those inboard and outboard, whcih were accessible to the squeezer.On to the elevators next.
Close-up of a blind rivet with pulling pin most of length.
