Cleve's Web Site
Date:  6-25-2007
Number of Hours:  3.50
Brief Description:  Tapped roll bar-Mounted canopy handle
We enlarged the undersized holes in the roll bar and tapped them for #6 screw. Then we fit the center strip on the canopy, inserted the canopy locking handle from inside, marked how much we needed to shorten the rod to fit the outside handle, took the handle off the plane, cut it off with a pipe cutter, and drilled the outside handle and shaft with a #29 drill, then enlarged the holes to #19 and tapped the unenlarged back of the handle for a #8 screw. All seems to fit nicely! See Image #1.
Canopy handle
Canopy handle
