We finally started making some progress on wiring the panel! Claude installed the grounding block on the bottom of the right subpanel and ran some #8 wire out to the battery ground. I put all the pins into the 15-5 socket completing the wiring of the pitch servo. John came down to show how it was done. These tiny pins are really difficult to handle. We will have more trouble with the roll servo because its cable came from Stein Aero and the color coding is different. I then began putting pins on the wires that will go in our main plug. This includes the magneto wires, nav lights, strobe power, battery relay, alternator relay, etc. All in all, I think that there are approximately 20 wires that need pins crimped on and inserted in this one socket. This should keep me busy for a while, don't you think.
