Brief Description: Primed Components & Installed Gap Farings
Primed gap fairings, access hatch and wing doublers with etching primer and sealing primer. Installed gap fairing s and access hatch. Modified tools for installing the leading edge with the rivets in the proper direction according to the plans. Riveted leading edge to the center spar. Riveted on inboard top skin and wing walk doubler to the wing assembly. Touched up primer on the wing skeleton and aileron mounts. Clecoed on top outboard skin. Scarfed skin lap joints to center spar.
