Chucks Web Site
RV-7
Sec.7 - Wing
Match Drilled Gap Farings and Located AOA Ports
Match drilled, deburred, and dimpled gap farings. Located and attached AOA sensing ports. Fabricated draing port by access hatch to located the purge rod for the top wing water sump.
Used Larger Rivet With Hole to Locate Purge Rod
RV-7 Home
562
Ailerons
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Leading Edge
Vertical Stab
210
