SeaRey LSX
Date: 12-8-2012
Number of Hours: 3.50
Manual Reference: Sect 5 thru 14.5
Brief Description: More holes and checking fit, Carpeting
Cleaned up the carpet install, the butane soldering iron pen I bought did a great job trimming the carpet up and cutting holes for leg holes. Spent some time patching the excessively w i d e hole I cut for the bulkhead tubes, we'll see how that turns out, I have some doubts...
Mated the hull again, after pulling out mounting bolts, perfect fit, and plates worked great. I noticed a small area on the front runner, just in front of where the carpet stops that is easily visible from cockpit, I'll go ahead and put a little scrap carpet on this so it looks more professional.
Cut gear holes, installed bilge pump - Could not locate the hose clamp anywhere in the kit or on packing list so I think its a case of the manual being slightly ahead of the kit? Will go buy a stainless hose clamp in next few days...
Drill 4 small holes on outside pattern, use crayon to transfer to inside carpet
My helper agrees that the slot is too w i d e and we need to fix
Jon insisted on taking a picture of me...
