Brief Description: Main gear leg and main wheel axle installation
Finished installing the main gear legs. They are heavy and the close tolerance bolts need some Boelube and motivation to get them all in. Run an reamer through the holes just before the bolts go in clean out any possible burrs. Next the axles go on and you run a string between them to look to toe in or out and any mis alignment. I found the error between legs was well under .5 degree and not enough to install a shim to correct.
