Brief Description: Sand canopy and fill void with epoxy
Saned the canopy and frame to accept the epoxy layup. Rough sanding until there is no gloss then clean the area and fill the void between the front edge of the canopy plastic and the fuselage. It's a small area but the idea is to get the area flat to the canopy angle so the fiberglass can be applied in the next step. This is all straight forward and the epoxy is colored black with epoxy pigment to match the glare shield since this epoxy will be visible from inside.
