Started on the installation of the main fuselage harness. There are left and right harnesses and they attach to the existing tail and wing harness connectors that are in the respective kits. It goes in pretty straight forward and the only problem I had is the control stick connector will not go through the holes in the cover ribs. The right harness contains the power recepticle between the seats and each side has the jacks for the headsets and they just need to be installed in the pre drilled floor boards.
