Brief Description: Fit and match drill rear window
Had some help available today so we got the rear window installed. It's all very straight forward and we had no problems. The fwd edge still needs to be trimmed flush with the shim but I can do that later. I modified std drill bits to work with the plext and they worked out fins with no chips so far or cracking. the 2 notches for the roll bar were done with a moto tool and sanding drum on low rpm. It worked out very nicely and fits well with no rubbing.
