Attached the firewall assembly to the front floor and tunnel assembly. Tank sealant goes on the parts that touch the stainless tunnel and firewall to prevent any leaks. Riveting the parts together is pretty straight forward. Attach the fuel selector valve plate (note orientation) snd then place the forward spar assembly on the floor pansand cleco. These will be attached with bolts and rivets in the next session.
