Installed the dimmer pots. The Garmin 3 pots were way too long on the shafts so I had to cut down the shafts to make a better fit to the panel. Dremel and a cut off wheel cut the shafts easily. Moved on to installing the ignition and master switches. Panel starting to look really good !
