Brief Description: Match-drilled HS-412PP, HS-413PP, and HS-411 sub-a
Accomplished a lot tonight. Match-drilled the HS-412PP and HS-413PP to the rear spar. That went smoothly... pretty straight-forward. Had to be careful not to mess up the powder coating.
Next, I assembled and match-drilled the famous HS-411 sub-assembly. For some reason, was nervous about this, but it worked out just fine. Tomorrow night I'll deburr that and maybe prime the bearing - need to research/think on that for a bit. If so, I'll grab some NAPA 7220 - seems to be popular now.
Whew.. now the elevators will have a play to hang... nice. :)
