Brief Description: Match-drilled HS609PP and HS-603PP
Made some good progress tonight. Match-drilled the HS609PP and HS-603PP using a #30 bit called out in the instructions. Also marked the holes for the HS-708 ribs to be drilled to #21 per the plans. Will probably do that tomorrow night.
The pictures today look like airplane parts, kind of... the rear of the horizontal stabilizer, anyway!
