Worked on a few small things after finishing the primer system. I fabbed and installed the clamp to hold the SCAT tube for the cabin heat. This is just a strip of stainless with a couple holes.
I also installed one of the fittings I received in the mail today. This fitting is a straight nipple, but has a 1/8" NPT port for a sensor. I used this at the outlet of the red-cube and the 1/8" port is for the fuel pressure sensor fitting.
