Today I finially got around to finishing the exhaust installation. I swapped out some hardware in the hangars for a more appropriate length. I also drilled the allignment holes and installed the clamps that hold the muffler/tailpipe to the crossover system.
I also reinstalled the engine rear baffle and mounted the oil cooler. I need to pick up another fitting since the oil filter interferes with the oil return line. I'll replace the straight fitting with a 45* and it should be good to go. I haven't quite figured out how I am going to route the crankcase vent line. The filter is in the way of that also.
