Just a couple misc things this evening. I replaced the aluminum hard lines for the gascolator to primer valve, and the line that connect the two oil pressure sensors. I made new lines out of stainless steel to reduce the possbility of failure. These lines are mounted on the firewall, so they aren't subject to the same vibration as if they were engine mounted, but better safe than sorry. As a bonus, the SS lines won't burn through in a fire like the aluminum lines (although the fittings are aluminum).
