Brief Description: Fuel Hose Routing and FF Sensor 2
With the engine mounted again I was able to mess with the fuel line routing some more. I used various fitting I had around to experiment. I will change to the proper steel fittings, but the aluminum is good for now.
It turns out the the fuel line from the gascolator to the engine pump is just the right length for the pump to the red-cube. I can just order another one of these lines and a could fitting. Of course that hose is 70-something dollars...
I am happy with the routing I came up with. I will install the oil cooler and line to make sure they dont interfere before I finalize the layout.
