I mounted the pitot tube and routed a line from one of the bulkhead fittings to the pitot tube.
To remove the pitot in the future, I'll reach in through the inspection hole and disconnect the line at the bulkhead fitting. The pitot can then be pulled down and the fitting at the pitot disconnected. When I install the dynon AOA pitot, I will just have to make new lines and use the second pitot line.
