Brief Description: Left Wing Bottom Inboard Skin 1
Finished the rivet layout for the wing access panel and drilled to the wing skin.
Hung the inboard skin and drilled to the spars and ribs. I left the overlap portion undrilled for the tim being. I am waiting on some parts from Vans, one of which is a new rib. I want to install the rib prior to finishing the lap joint. Other that that one spot, all the wing skins are drill on...Yeah!
I did go ahead and taper the skin overlap. I didn't take a picture at the time, but here is a later picture wing the joint showing.
