COLIN'S WEB SITE
Date:  9-27-2009
Number of Hours:  0.00
Brief Description:  Left Wing Bottom Outboard Skin 4
After cutting out and finishing the wing access hole, I trimmed the skin for the aileron. Making a ~47" cut with hand shears was fun. I finished the cut with the file, edge deburr tool, and deburr wheel.
Re-hung the skin and completed drilling it to the structure (except for the skin overlap rib). I started to lay out the rivet lines for the access panel doubler. The plans for this part don't make much sense, they have no rivets going through the bit of angle riveted to the rib. The plans also have the nutplate locations on places they could not even fit... I'll do a bit of research on this before going forward. Enough for today, it is dinner time.
