COLIN'S WEB SITE
Date:  12-5-2009
Number of Hours:  0.00
Brief Description:  Left Wing Closeout 1
I had previously clecoed the OB skin in place, but I had to remove it because I forgot to put in the nutplate for the Pitot heat ground. I put in a 10-32 nutplate on the rib outboard of the bellcrank. I then crimped a terminal onto a short section of 14awg and routed this along with the power wire through some spiral wrap. Before I attached the nutplate, I cleaned some primer off with a scotch brite pad and the masked off a square and shot some more primer. I then clecoed the OB skin back in place. The ground wire is attach with the following hardware per AC 43-13 table 11-15:
10-32 nutplate
Aluminum Washer
Terminal
Cad Steel Washer
Lock Washer
Bolt
Continued to rivet the lower skins on the left wing. Riveted the bellcrank area and pitot mount doubler. Also riveted the skin overlap seam.
I received a much needed package from Aircraft Spruce that included some more 10-32 nutplates. For my wing electrical connector, I had used #8 screws but decided it would be easier to install the backing plate with bolts. I drilled out the #8 nutplates and replaced them with #10 and installed the connector bracket in the wing.
I need to vaccume out the wing...
