Brief Description: Left Wing Prime and Assembly 17
I finished riveting the inboard lower skin in place (except for the outboard seam). Everything went well and I was able to use all solid rivets. I started by riveting all the skin to rear spar rivets in the WW area and then worked up the ribs just a bit. I then worked outboard up each rib and along the spars. I have tons of pictures of the rivet shop heads for and future inspection purposes...
