COLIN'S WEB SITE
Date:  12-20-2013
Number of Hours:  0.00
Brief Description:  Panel Paint/Label 1
Over the course of a few days I painted my instrument panel. I used the same paint system as the interior. PPG OMNI Urethane with an epoxy primer. The panel received a number of coats with block saning in between to provide a perfectly smooth surface. Since the panel will be labeled and then painted with clear, I had to sand the final finish to give something for the clear to adhere.
