Today I decided on a mounting location and wire routing for most of the EMS. I can't terminal anything FWF until I decide exactly how I am going to pass the wires through the firewall while still providing solid fire protection. For now I drilled a hole and put a snap grommet in, but that will not be the final solution.
I am mounting as much as possible to the sub panel to make future access easier. I can get to the sub panel while sitting comfortably in the seat vs laying over the spar under the panel. The most challenging part of working on the electrical is figuring out how to route everything. The connections themselves are easy.
