Since I am getting close to putting the plane up on the gear I wanted to get as much done in the tail as possible. I worked out the routing for the Skyview network harness to the ADAHRS, the OAT probe in the tail, the pitch servo wire, and the tail light wires. For the wires running out to the tail I put them in a teflon spiral-wrap to keep them from flopping around and provide some additional chafe resistance. I also installed a number of cushion clamps along the center tunnel to run the wiring. There is a ton more to do, but this is a start. I definately need to blow the dust out of the fuselage. Some of that is overspary from when I did the cockpit paint.
