More work today installing the plumbing (again). I installed the line from the selector to pump and pump to gascolator. I also installed the brake lines to the selector housing. I haven't decided exactly how I want to support the lines so I was trying out some different ideas. I will probably use some more of the poly tube as a chafe guard.
I also drilled the lower holes on the brake pedals for the brake cyl. and bolted them in place. I added all the cotter pins so the assembly is complete. I fit the pedals and brakes back into the fuselage.
With the pedals in I put the poly tube on the right vent line and installed it in the fuselage.
I torqued and marked all the lines I don't plan to remove again.
