Brief Description: Empennage to Fuselage Assembly 5
With the horizantal stab set in place, leveled and trued to the fuselage, I drilled the holes for the forward attachment bolts. I also drilled the last two holes for the rear spar attachment. I made a couple of 0.63 shims to go under the front spar to adjust the level for the stab. FYI: the rivets in the aft deck are not set, I put those in place to help keep things alligned where I coudn't fit a cleco.
