With the right elevator basically done I started in on the left side. The left elevator houses the trim system, so it is a bit more complicated. Today I match-drilled the spar and ribs to the skin. deburred everything and primed the parts. I then riveted the internal structure together.
I am using electric trim, so I fitted the trim servo to the elevator and riveted the brackets together,
