Today I removed the forward canopy decks and made a slight tapered bend where they overlap the longeron. This will make the deck sit level even over the twist in the longeron.
I then cut some angle to attched the deck to the sub-panels. The interface isn't 90 degrees, so I had to bend the angle a bit. I also had to notch the angle to clear the beading in the panel. Everything went together fine.
