When I fit and drilled the gear weldments to the fuselage there were two holes that I couldn't access to drill since seat rib flanges were in the way. To finish up the weldments, I bolted them to the wing spar (off the plane) and drilled the last holes. I then deburred all the holes in the gear weldment.
