Brief Description: Prime and Rivet Right Aileron Stiffeners
Primed the stiffeners and aileron skin with NAPA 7220 self-etching primer and set aside to dry. Later in the afternoon I set up the C-frame and back-riveted the stiffeners to the skin. Got out the bending brake I made for the empennage and started bending the aileron skin closed. Did not have much success, as I bent the skin as much as I could but it would spring back. Started research on other techniques to bend the trailing edge.
