Brief Description: Make New F-00098 for Ground Power Plug
Ken has a good setup for his ground power plug so I copied it. I requires a deeper F-00098 than the standard one from Van's. I used the original to layout a larger version on some sheet stock. Cut the edges and then drilled the corners and used the dremel to cut the hole for the plug. Used files to clean up the hole. Match drilled the rivet holes in the new piece. Drilled the mounting holes for the plug receptacle. Checked the fit.
