Brief Description: Drill for Prop Pass Thru, Insulate Buss Bar
Used the drill guide and the same process as the mixture pass thru to drill the prop control pass thru. Deburred all holes and installed the eyeball.
Dis-assembled the master contactor and starter contactor to get the buss bar out. Used some heat shrink tubing to insulate the bar. Checked the insulation with multimeter. Reistalled the contactors and buss bar.
