Found that one hole on the hinges came out too low on the battery box to dimple the hole. Made a new hinge and drilled the hole higher . New hinge will cover the errant hole in the battery box. Dimpled holes in hinges and box with the squeezer. Cleaned up battery box and sprayed some satin black Rustoleum to cover edges of holes and scuffs made during the work. Made F-7127B spacers for the battery hold down bar per the plans.
