I used the squeezer to rivet the heat baffle to the F-782C center cover. Also used the squeezer to rivet on all the nutplates. Found a piece of trex decking that was the correct thickness to provide a spacer to set the F-782C height between the ribs in the forward fuselage. Put it in the plane for a test fit. Marked the location for the side rivets on the center cover per the plans.
