Primed center cover, heat baffle, and access plate with NAPA 7220 self etching primer. Set aside to dry.
Removed blue plastic and edge finished F-983 fuel valve cover. Removed plastic and cut off triangular extension on fuel valve plate. Edge finished with files and scotchbrite.
Made the F-782D angles per the plans. Edge finished the F-782A covers and marked them for mounting holes.
