Finished painting the brake pedals and set them up to rivet. Used the squeezer to rivet the angles and the master cylinder mounting arm on each pedal. Hung the pedals using a single AN3-56 bolt and a combination of thick and thin washers as required to get a good fit with no resistance. Note the bolts must be inserted from the inboard side to allow removal once the assembly is in the plane.
