Brief Description: Prepare to Final Install Roll Bar
To prepare for final install of the roll bar I marked the legs for trimming to match the cockpit sides. Removed the roll bar and clamped it on the bench. Used the angle grinder to make the rough cuts on the legs. Used files and emory to clean up the edges. Repeated for the other side. Test fit and worked the edges until fit was good. The shims also had to be modified to match the cockpit edge.
