Frances helped to pull the fuselage out of the shop and set up in the driveway to prime. Also put up sawhorses for small part priming. Shot NAPA 7220 primer for aft fuselage, horizontal and vertical stabs, and small parts. Let everything dry and removed most of the masking. Turned the fuselage around and we put it back in shop. Ready to start on firewall forward.
