I'm finished with work on the tail pieces and decided to touch up the primer that was scratched in all the assembly and dis-assembly while fitting the tail. I wiped down all surfaces with a damp cloth and dried them, Then I masked of areas near where i would spray the primer. Did this for the fuselage and the stabilizers , rudder, and elevator.
Also torqued the jam nuts on the rod end bearings and marked with torque seal.
