The tailwheel fork had been sitting on the bench since coming back from powder coating. Thought I would need it for setting up the rudder swing so I got it out and reassembled the parts. Drove out the roll pins we used to hold the end on in powder coat process. Replaced with bolts and torqued. Marked bolts with torque seal. Assembled the remainder of the components after cleaning everything and applying fresh grease.
