Back at work after a long break for travel to Hawaii to visit our daughter. Drilled the F-719D rivet holes. Clamped in place to check the swing of elevators. Found the back edge of one elevator horn hit the aft bulkhead before the horns hit the stop. Used the angle grinder to trim the aft edge of the elevator horn, then filed to smooth. Reinstall elevator to check the swing.
